Midi Organ
This project entails multiple Midi controller boards to control a huge organ consisting of about 3000 pipes.
0 followers
A build-in-progress organ is in need of some control electronics. We decided to make the organ midi compatible to be able to do lots of fun things with it in the future. Recording and playback will be possible, also remote control of the organ will be in reach.
We have chosen to run the midi connection over an RS485 bus to be able to transfer longer distances. we use ethernet cable for interconnections. An 48V line is also available on the ethernet cable to power the control electronics.
The first module we developed is a configurable 64 channel input/output module. This module can be used to read inputs such as keys or register selection. The output are design to drive solenoids that open air paths.
This is an ongoing project and loads of design decision are still to be finalized.
20201214_232815.mp4
Midi RS485 converter
MPEG-4 Video - 25.48 MB - 03/25/2021 at 18:44
Download
20201220_133258.mp4
Early version showing menu structure
MPEG-4 Video - 48.04 MB - 03/25/2021 at 18:39
Download
20210109_181926.mp4
keyboard with midi converter driving output board
MPEG-4 Video - 21.98 MB - 03/25/2021 at 18:36
Download
20210322_172657.mp4
input and output working together
MPEG-4 Video - 4.22 MB - 03/25/2021 at 18:35
Download
Dan Maloney wrote 03/25/2021 at 20:42 point
I see that pipe organ and I hear "In a Gadda da Vida". And that's not a bad thing.
