Face-off - how it could happen
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
yann-guidon-ygdesYann Guidon / YGDES 08/03/2021 at 01:120 Comments
As I gain confidence in that PEAC thing, I think that soon should come the time to compare its behaviour with a big competition. This will be even easier once I get my Pi cluster in working order.
It's only fair to compare the 32-bit version with other 32-bit checksums, in particular Fletcher32 and CRC32.
Maybe I can also compare with some 16-bit algos with a "compacted" PEAC signature. ADD16, Fletcher16, CRC16 and IPsum would be good candidates.
This will also be an opportunity to compare the effect of the end-around carry, and settle the debate concerning the mixing method : whole word or half word ? XOR or ADD ?
Considering that on average, only one error will be detected for every 4 billion tests, this is going to be slow and require a smart algorithm running on tens of cores to collect data,
The next question is : what is the expected bit error model ? What is the buffer's length ?
Another thing to measure and compare is the histogram of the signatures for small blocks of small values.
