w32 "Just in case"
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
yann-guidon-ygdesYann Guidon / YGDES 05/09/2023 at 11:510 Comments
The recent sieving effort has not yet slashed the hope that w32 be perfect or maximal. The sieve can only tell if a modulus is not either of them but the required amount of sieving makes the sieve almost as large as the number to be even 1/2 accurate.
But since the possibility is not ruled out so far, the chances are still good that it might be. And considering the amounts of time involved in this research, it could be worth it to have at least a "try": it would be good to start mapping its structure, even partially. In 2 years, I have not even considered scanning the primary orbit, it could be short and that would be the end of it !
[yg@localhost gPEAC_500K]$ /usr/bin/time ./gPEAC_scan 4294967296 4294967296
4294967296 M
1 candidates among 1 numbers (100.00000%)
1 hits among 1 candidates (100.00000%)
17.18user 0.00system 0:17.21elapsed 99%CPU
OK... sigh... The scanner says it's maximal but only lasts 17 seconds ? Time for more investigation.
Aaaaaand it seems that it is caused by an overflow in the computation of the orbit length... No wonder it stops early. Or maybe that's just the case that w32's primary orbit's length is 13.603.546.275 only :-/ So this case is closed after 2 years. Let's now look at the other possible orbits (those that the sieve has not ruled out):
How is it possible to be this unfortunate ?
Time to reconsider the goals. Let's see if w31 is really worthy more efforts.
Fortunately, there is a hit with sqrt(2^39)
