With the new harvest, I estimate that the perfect and maximal orbits under m=1M is around 100K.
This starts to make quite a large .h file to include in the sieve generator. Not that it's such a concern but scalability, you know.... And embedding such a huge array in the constants area of a program is not such a great idea, particularly if it is meant to evolve fast. However, playing with .h files is good because they are easy to process with UNIX scripts in bash, and this saves the pain of writing C code to import the text file, with error management etc.
But the list of orbits might get even larger in the future and I believe it's a missed opportunity to make things a bit better so, after staring at the numbers, I came to the conclusion that differential coding, or "delta coding", is an easy and interesting thing to do. So I now only encode the difference between consecutive orbits.
Using partial/incomplete data, I came up with this quick and dirty script to produce the following histogram :
S=0
sed 's/ -//' gPEAC.000002-$MAX.txt | while read -r line ; do
echo "$(( line - S ))"
S="$line"
done > gPEAC.000002-$MAX.diff.txt
sort -g gPEAC.000002-907575.diff.txt |uniq -c |less
6202 1
5127 2
5055 3
6549 4
5979 5
4706 6
3787 7
3292 8
3660 9
3889 10
3380 11
2289 12
1967 13
2017 14
2699 15
1706 16
1314 17
1508 18
1341 19
1505 20
1005 21
1002 22
747 23
845 24
942 25
702 26
441 27
567 28
613 29
541 30
390 31
351 32
370 33
296 34
335 35
283 36
232 37
196 38
173 39
265 40
157 41
110 42
112 43
157 44
136 45
91 46
64 47
103 48
83 49
74 50
75 51
41 52
33 53
55 54
60 55
34 56
40 57
28 58
31 59
31 60
21 61
19 62
20 63
15 64
17 65
17 66
15 67
16 68
9 69
9 70
5 71
13 72
3 73
7 74
11 75
7 76
5 77
4 78
5 79
6 80
3 81
2 82
1 83
3 84
1 86
3 87
1 88
1 89
2 90
1 91
1 92
2 95
1 96
1 99
1 100
1 101
2 102
1 103
2 104
1 105
1 114
1 119
So far the largest gap is 119, which fits in a uint8_t instead of the previous uint32_t. The .h source file shrinks from 628041 to 275813 bytes, not a 4× gain as the binary format but still good and compresses well : 198495--->70512 !
There is still much room for improvement, for the numbers below 16, but I won't get into this... yet... if ever ?
When the scan reaches a point where the gap goes beyond 255, I'll have to reconsider my approach but so far, it's a pretty little hack and it gives a bit more insight on the spread of the perfect and maximal orbits. I observe that their density decreases quite slowly... Though no formula yet.
