Features
  • Customized for Raspberry Pi 4 Model B, make it become a real desktop PC for all.
  • Re-locate all of the ports to the rear, and make GPIO pins easy to access with at-a-glance pin out legend next to the gpio.
  • An ice tower cooler was built-in, that keeps the CPU down to 40℃/104℉ even when overclocked
  • A nice and solid metal case, customized cuts for all ports, lamps and wifi signal, while enhancing the cooling effectiveness, lightweight enough to make the Raspberry Pi 4 become a real portable pocket PC.
Specification
  • An air cooler that keeps the CPU down to 40℃/104℉ even at its full throttle, and yes, it has the kind of RGB every gamer hypes about.
  • A GPIO adapter board that puts the GPIO to the back.
  • An adapter board that rearranges all the ports to one side.
  • A push-button switch convenient to do a safe shutdown.
  • A 0.96 inch OLED display shows IP, CPU/memory load by default. You can also program it to display anything you want.
  • A nice and solid metal case, customized cuts for all ports, lamps and wifi signal, while enhancing the cooling effectiveness.
Package Including
  • 1 × Upper cover plate with OLED display
  • 1 × Lower cover plate
  • 1 × GPIO adapter board
  • 1 × HDMI adapter board
  • 1 × ICE towel cooler
  • 1 × Power switch
  • 2 × Wires for power switch and screen
  • 1 × Power supply board for fan
  • 4 × Rubber feet
  • 1 × Elastomeric heat-conducting pad
  • 1 × Screw pack
