(work in progress...)
Introduction
Is the design of a 68000 single board computer (SBC) difficult? If you see the huge chip (dip 64) you should think so, but it is relatively simple. Compared to other CPU's like the Intel 8086, the address and data-lines are all directly available. Boards with 8086 CPU needs several latches to demultiplex the address and databus, and extra chips means extra wires.
For a simple design you need to connect all the address-lines of the CPU to the address-lines of the ROM and RAM, dito with the datelines. Besides that, a couple of logic chips will complete the design.
In this chapter I explain how I designed the SBC; I hope this will inspire you to build a SBC also, wether is is 68000, 6502 or Z80!
Design goals
The design had to be simple (KISS/keep it simple, stupid); a minimum of chips but "by the book". It should run a pascal compiler I was writing:
I read a couple of books and magazines I found about this subject and took what I liked.
Memory map
The MC68000 cpu needs ROM at startup at address 0x0000 till 0x0007 for stack pointer initiation and program start address. On the other hand the (interrupt)vectors are located in the first 1 KB, which you like to be in RAM-memory. But hey, KISS we decided, so the ROMs are at 0x0000and the vectors are fixed!
A 74LS139 demultiplexer gives you 4 banks for ROM/RAM/IO. The popular 62256 SRAM's are 8 x 32K large so every bank has a size of 64K. (Remember that the data-bus is 16 bits wide, so you always need two ROM chips and two (or four) RAM-chips).
BankAddressFunctionChipSize
0.0x0.0000 - 0x0.7FFF
0x0.0000 - 0x03FFF
EPROM
EEPROM
2x 27C128
2x 28AT64
2x 16KB
2x 8KB
1.0x1.0000 - 0x1.FFFFSRAM2x 62256
2x 32KB
2.0x2.0000 - 0x2.FFFFSRAM2x 622562x 32KB
3.0x3.0000 - 0x3.001E
0x3.0001 - 0x3.0003
VIA / IO
UART
MC6522
MC6850
16 bytes (even bytes)
 2 bytes (odd bytes)
Power circuit
The good old and uncomplicated! 78S05 linear voltage regulator gives 1.5 Amp; more than enough for the system. Although this kind of regulators spoils a lot of energy, this is how it was done the 90's.
Lineair voltage regulator 78S05
Reset circuit
The CPU has two lines (/HALT  and /RESET) which has to be asserted for at least 100 mSec at startup for a proper reset. A fine task for the good old 555. But  the /HALT-line also is an output that signals the CPU is running. So it's better not to connect /HALT and /RESET together. That means extra glue logic (open collector inverters 74LS05) and a LED as run-indicator.
Reset circuit 555
Run indicator
CPU clock
The CPU is running on 8MHz; to get a nice 50/50 duty cycle a divider is added, although I have seen many projects with no divider. Perhaps you can skip that part, but I used the other part of the 74LS92 also for the correct clock for the UART.
Memory decode
/DTACK & /VPA
The MC68000 can work asynchronous (/DTACK) and synchronous (/VPA). /DTACK  is used for ROM and RAM; with this line you can add wait-states, which we don't want. (For a simple design it's better to lower the clock speed if the memory is to slow). /VPA is for MC6850 (UART) and MC6522(VIA) devices. Be aware the /DTACK and /VPA should not be asserted at the same time.
UART clock
The MC6850 has a programmable internal clock divider of 16 and 64 for asynchronous operation. Using a standard crystal of 1.8432 MHz divided  by 3 or 6 (74LS92), gives us the usual baudrates. I am using hardware division of 3 and a programmable division of 16, for the comfortable speed of 38.400 baud. (The remaining 2 divider of th 74LS92 is used for the CPU-clock.)
74LS92
Hardware divider
UART MC6850
Programmable divide by 16
UART MC6850
Programmable divide by 64
÷1 (B)115.200 Baud(28.800  Baud)
÷3 (Qc)38.400 Baud9600 Baud
÷6 (Qd)19.200 Baud4800 Baud
UART 6850
VIA 6522 (IO)
Interrupts
The MC68000 support classic 6502/6800 peripherals, and also prioritized interrupts. A 8 to 3 multiplexer connected to IPL0 / IPL1 / IPL2 gives 7 interrupt lines. But if you only need one, skip that extra chip.
Both the UART and the  VIA have open collector interrupts, so these pins are connected together to IPL2 as IRQ4 with a 4K7 resistor pulled to Vcc.
Interrupts
RTC
SD-card
