moteus-n1 semi-automated test fixture
A project log for moteus brushless controller
Open source, compact, high performance, FOC based BLDC motor control
josh-pieperJosh Pieper 07/15/2023 at 11:220 Comments
Now that the moteus-n1 is finally released, I've documented the test fixture I made to perform end-of-line testing on it.  Most DIY test fixtures are clamshell affairs that can probe the top and bottom of the board.  This is 5 sided, probing top and bottom, as well as 3 of the 4 sides in order to test the right angle connectors.
I've got a longer writeup showing how all the mechanics work up here: https://jpieper.com/2023/07/15/5-side-pcb-test-fixture/
