Ready for Signal Processing
A project log for Radar Sensor
This project will be using an InnoSent IPM 165C and / or IVS 362 module to sense distance and motion towards / away from the observer.
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 05/07/2021 at 09:470 Comments
The Radar module has been mounted on the DIY PCB with a 2 stage op amp for each signal output. Tested all ok. Great care needs to be taken to prevent damage to the module by static voltage. Next step is to hook up the oscilloscope and have a look at the output wave forms again.
