LCD driver board for the Surface Screen
A project log for Portable 2k monitor from a Surface Pro 4
Make a 2K portable monitor out of a Surface Pro 4.
dominic-emond-belangerDominic Emond-Belanger 04/24/2021 at 17:481 Comment
First of all I need to buy a LCD driver board for my Surface, the part number for the screen is LTL123YL01-007 made by Samsung. I look around and found this board on Ebay.
This driver board is power by a Realtek RTD2795 that can drive a LCD up to 4K so it should drive the 2K Surface screen with no issue.
The board features are :
Note that there is a smaller board connecting between the LCD panel and the FPC ribbon cable, this board is use for the LED backlight driver and convert physical connector to match the one on the LCD panel.
After ordering the LCD driver board, I found and ordered this Surface Pro 4 chassis on Ebay.
It came with the battery, maybe I can found a way to reuse it to power the screen later, it would be a nice feature.
Jacob Miller wrote 01/30/2022 at 16:46 point
can you update the control board link to one that is available? Thanks!
