Dynamic USB Descriptors
A project log for Chocolad Keyboard Hacking
Make it run CircuitPython
dehipudeʃhipu 05/15/2021 at 13:042 Comments
A new feature landed in CircuitPython recently, that allows us to do a neat little trick: we can show the CIRCUITPY disk and Python REPL console, or not, depending on whether a certain key is pressed when the keyboard is powered up or reset.
Why is this important?
I find it rather distracting when my keyboard shows up as a disk and serial device, especially when I'm working with other CircuitPython devices — it's sometimes hard to tell which is which. On the other hand, the way you could disable the disk and console previously involved compiling and flashing a special CircuitPython image, as this was a compile-time option. Having to re-flash your firmware to see the disk again every time you want to make some small change or tweak is not very convenient.
So now we can make it so that it's just a keypress away.
All I needed to do is to create the following boot.py file:
import board
import digitalio
import storage
import usb_cdc
import usb_hid
row = digitalio.DigitalInOut(board.D4)
col = digitalio.DigitalInOut(board.A2)
col.switch_to_output(value=0)
row.switch_to_input(pull=digitalio.Pull.UP)
if row.value:
    storage.disable_usb_drive()
    usb_cdc.disable()
usb_hid.enable(devices=(usb_hid.KEYBOARD,))
row.deinit()
col.deinit()
The board.D4 and board.A2 are the row and column of the key that I want to use for the check. The rest is pretty self-explanatory.
Dan Halbert wrote 05/15/2021 at 13:40 point
Thanks! I plan to add "boot" keyboard support next.
deʃhipu wrote 05/15/2021 at 14:57 point
That's great. And I also suppose that with the ability to configure your own HID descriptors, an n-key rollover keyboard should be already possible too.
