The age of laptops dominated when lions were routinely commuting & needed the same confuser at home & work.  The need peaked when commuting to the city.  Commuting started declining in 2018 & may finally be over for the kinds of things lions have done for the last 20 years.  There may still be a need for a laptop, but nothing as regularly used or as powerful as before.
Years ago, a pretty competitive laptop was only $400.  Nowadays, nothing below $1000 is anywhere close to what a developer would need.  Tablets are nowhere close to even the cheapest laptop.  What's over $1000 is still manely what lions already had 6 years ago.  Keeping an old laptop from 6 years ago working may be more practical than buying any new one.   It got the lion kingdom wondering if a home made laptop can finally do better.
Reviewing the
https://frame.work/
modular laptop, it's not much different than the others, very small screen, very bulky, no stated battery life.  There was also the raspberry pi laptop, the OLPC laptop, the netbook laptop.  The problems come from trying to use general purpose components.  Laptops just can't be every high performing unless every piece is purpose built just for 1 laptop.
Lions believe the ideal laptop is a bare screen & keyboard with no confuser.  The confuser would be a separate brick which would fit in a backpack or a pocket.  Maybe the confuser could be a phone.  The different parts would need their own batteries.  Everything would be connected over wireless.
The display
https://www.amazon.com/dp/B0885RN8FQ
Suspect the most compact display would be a used laptop LCD with an HDMI converter, but there have recently appeared portable 15.5" 1920x1080 monitors for under $150.  This one burns 5V/2A from a USB connector & weighs 1.8lbs
Wireless HDMI
https://www.bhphotovideo.com/c/product/1374507-REG/iogear_gwhdkit11_wireless_video_kit_150.html/
is another $150.  It's gone from something that was being marketed towards consumers 15 years ago to a boutique item for content creators, thus much higher prices.
The keyboard
There are el cheapo bluetooth keyboards, el cheapo bluetooth touch pads, or combos for tablets.  It might be more ergonomical to connect a wired keyboard & track pad to a microcontroller.  ($50) Keyboard/touch pad combos are 8.8oz.
https://www.amazon.com/Fintie-Ultrathin-Bluetooth-Multi-Touch-Microsoft/dp/B00XBTUK5M/
The keyboard & monitor would need some kind of structural support.  If they're joined together, they could share a battery.  The structure might be 3D printed or it might be wood.  It could also be some kind of wearable.
The confuser
This continues to be the most expensive part if a development machine is desired.  The mac mini has recently attracted some competitors.  They're all made by Beelink with a boxy form factor sized to accomodate a 2.5" hard drive.
https://www.amazon.com/Intel-Core-i5-8259U-Beelink-512GB/dp/B08T657SM1
While they're expandable to SSD & RAM modules which are bigger than a 6 year old macbook, there's no way to get a bare confuser without pitiful SSD & RAM modules included in the price ($470).  If a 2TB SSD ($200) & 32GB RAM ($200) get added on, it's $870.  It needs 19V 3A.  It might be hackable to 12V.  It weighs 2lbs.
Of course, there's always minimally viable portable confusing based on a raspberry pi with 8GB RAM & 64GB SD card ($100).  A raspberry pi + battery is still big enough to require the confuser to be a separate module from the monitor & keyboard.  This is why raspberry pi laptops are always bulky.
The confuser could itself be modularized into a removable storage unit & confusing unit.  The storage unit would plug into a raspberry pi when on a train & into stationary PC's in the 2 locations.  This would reduce the mass being moved around, but would no longer be cheaper than a commercial laptop.
Power
That just leaves batteries & battery chargers.  The keyboard would use a small USB brick.  The display would use a big USB brick.  The confuser might need a 6S, 5Ah Lipo ($70) 1.8lbs .  These would have bypasses for manes voltage.  There would also be a  remote power switch to switch on the confuser from the display.  The power systems might cost $150.
Options compared
A 3.8Ghz 4 core, 2GB RAM, 2TB flash, 15.5" laptop with this method would cost around $1500 with tax.  A similar Lenovo is over $1900 with tax (https://www.bhphotovideo.com/c/product/1543441-REG/lenovo_81yt0000us_15_6_legion_7_15.html/).  A macbook is easily over $3500.
A minimal raspberry pi confuser would be around $600 with tax, definitely more expensive than a Lenovo, so there is a crossover price below which it's not worth doing.
The time has definitely come when a portable confuser with similar power can cost at least less than a commercial laptop.  Of course, the lion kingdom makes no assumptions about the relative ergonomics of either method.  15" Macbook Pro's are 4lbs.  The Lenovo is rated at 4.6lbs.  The home made option would be at least 6 lbs.  The Beelink alone is 4.8x4.5x1.6".  Of course, the online specs are never very accurate.
From a purely weight perspective, a minimal option composed manely of the monitor, keyboard & smaller battery would be under 3lbs.  The low end 15" Lenovos are 3.7lbs.  The home made option with minimal confusing power definitely has a weight advantage over any commercial option.
A portable confuser with a confusing module separated from the user interface has never been tried before, but lions believe it could be vastly more practical.  At least the heat & weight wouldn't be on your lap & the confusing module could be upgraded separately.  It would definitely last longer than a laptop.
It's encouraging that display, wireless, & confusing modules continue to evolve to make this idea more affordable.  The lion kingdom definitely isn't going to move forward with this idea until the confusing power gets vastly ahead of a 6 year old macbook or there is a definite need for a laptop with 32GB & 2TB.
