PDP-11 on a FPGA
Build of Sytse van Slooten's PDP2011 on a FPGA
Builds include PDP-11/45 and PDP-11/70
FPGA Hardware
PDP2011 FPGA Builds
Disks (SD card images) that work with PDP2011 build
Front Panel
  • New Panel Design
    land-boards.com06/23/2021 at 15:57 0 comments
    I made a new panel design which should be easier to use. It has a single 36-pin connector with 4 ground and 4 VCC pins. It moves the connector to the bottom of the card.
    It should be easy to use white characters on black P-Touch labels to customize the LEDs and switches. The result should be like:
  • Jumpers, Switches, and Pushbuttons
    land-boards.com06/23/2021 at 10:40 0 comments
    Minimal Front Panel Design
    LEDs via the LEDS-SWITCHES card.
    • D4 = On while fetching instructions
    • D3-D1 = SD card status
      • D3
        • on = SD card installed
        • off = SDHC card installed
      • D2 = Read from SD card
      • D1 = Off when running, On when initialization is in progress
      • D0= Off when running, On when initialization is in progress
    Pushbuttons
    • SW9 - Reset
    Jumpers (J3)
    • J3-1 to -3  - selects drive type
      • J3-1 installed = RL
      • J3-2 installed = RK
      • J3-3 installed = RH
      • J3-4 to J-6 = unused
View all 2 project logs
teraz wrote 11/23/2021 at 14:30 point
Is possible moving this project to Orange Crab ? https://groupgets.com/manufacturers/good-stuff-department/products/orangecrab
and meybe put every switch, led and key on/off as board? Orange Crab have a Lipo
