New Panel Design
A project log for PDP-11 on a FPGA
Build of Sytse van Slooten's PDP2011 on a FPGA
land-boardscomland-boards.com 06/23/2021 at 15:570 Comments
I made a new panel design which should be easier to use. It has a single 36-pin connector with 4 ground and 4 VCC pins. It moves the connector to the bottom of the card.
It should be easy to use white characters on black P-Touch labels to customize the LEDs and switches. The result should be like:
