Finished
A project log for DIY Ringlight
The spotlights on my microscope didn't cut it. So I'm making a ring light to improve video quality.
nagupnagup 05/22/2021 at 17:570 Comments
Finally done with the project, it has definitely improved video quality (as far as it can be with the microscope itself being the limiting factor), the image is still a bit noisy but the ring light has helped remove shadows that were cast by the spotlights, I will still use the spotlights alongside the ring light though.
Spotlight only:
Ring light only:
