Microphone attachment for cheap headphones
05/18/2022 at 22:50 • 0 commentsThe indirect, bluetooth microphones built into modern headphones sound utterly terrible. The mane reason is all blueth microphones are limited to the 20 year old standard, 8khz sample rate & lots of compression.
There's a rare example at 4:10 of all the most expensive headphone microphones. Even without any singing or music, they all sound terrible or at least $400 instead of $500.
The 1st problem is the microphone cable is going to be a 2nd cable. Maybe it could be farstened to the speaker cable.
Most boom microphones have a hole in the side of an earpiece.
Top of the line pilot headsets have an extension under the earpiece.
Rectangular bed extension
09/09/2021 at 06:02 • 0 commentsThe idea came of extending the bed in the Y direction to 400mm. It would require a longer track, longer belt, & longer hot plate in the Y direction only. It would allow the lion kingdom's largest panels to be printed in 1 piece.
A rectangular expansion requires far less new parts, takes far less space & would be far more used than a square expansion, yet only square expansions are made. The cheapest 400mm one costs as much as a new printer.
https://enderextender.com/collections/ender-3/products/ender-extender-400-for-ender-3-non-pro
It could be ground down to 400x235 to fit in an apartment, but that would throw away all the other parts required for the 400x400 upgrade. The next idea is just finding a longer track, longer belt, & longer hot plate. Ideally, the hot plate would be divided so the entire thing didn't have to be heated for every print.
Pop socket
08/06/2021 at 19:31 • 0 commentsThe lion kingdom has always believed the inventor of the pop socket has gotten over compensated through a very effective patent enforcement program. By now, there's no reason such a simple thing should still be even $10 in fiat money.
Lacking a desire to spend $10 to reverse engineer such a thing, there was finally a good profile shot of the mechanism. It's basically 2 toilet plungers stacked. A system of 2 curved profiles & 2 square profiles make the toilet plungers. The curved parts bend & lock into an inside out & inside in position. The square parts create a vertical offset required by the curved parts to lock into the inside out position & divide the height of the retracted position.
The trick is TPU delaminates if bent across the laminations. Something would have to be done to strengthen the laminations or it would have to be printed as a flower. The only reason it locks into 2 positions is the tension propagated around the circle. It wouldn't work with separate flower pedals.
Unheated bed
07/30/2021 at 06:31 • 0 commentsThe answer is yes. You can print without heating the bed, if the apartment is already 93F & you have a grip bed. It doesn't stick as well, but it costs less & it doesn't make the apartment hotter than it already is.
