Video of PnpAssist
07/20/2021 at 16:39 • 0 commentshere is the video of the machine
Controller Board Production
06/21/2021 at 08:41 • 0 commentsIt is time to get a fabricated PCB board instead of this messy one. I build the first one with the in hand components
I have designed and order the New Controller Board from PCBWay. All the design files are in the GitHub Repo.
Proof of Concept with Cross Table
06/15/2021 at 08:53 • 0 commentsI started with a simple motorized cross table under the microscope for the proof of concept. I also use a cross laser beam to highlight the place of the component. It worked well. The down side of this design is I can not rotate the board while placing the component. SMT components has various orientation mostly 90 45 degrees on the board. So freely rotating the board gives me a lot of freedom while putting the component on the PCB.
