Library Generator Now Online!
A project log for Standalone T9 Predictive Keyboard
Fast, tactile, one-handed typing with a T9 powered macropad. Runs CircuitPython, so you can drag/drop your own custom dictionary.
guy-dupontGuy Dupont 07/06/2021 at 14:310 Comments
A few updates:
1. You can now turn any list of words into a library file to be used with the firmware for this project. You can either run it locally, or use the version I have hosted online here.
2. Added "official" support for the Adafruit QT Py RP2040. My macropad is pin compatible with both the QT Py RP2040 and the Pimoroni Tiny 2040. It should work with the SAMD21 based QT Py as well, but I have not tested it. You're gonna want to use external flash if you go that route.
3. I got a bunch of parts in!!! Have a modest supply of PCBs, Key caps, switches, and compatible micro's. More on that  soon.
QT Py RP2040 <- -> Tiny 2040
