for future experiments on the way to achieve some LTP system.
Neurons can join or out dinamically according to things I will going to test in this mode...
Only hidden neurons can "explore" and when this is allowed to join and this is near to some input neuron then act as "parent" else act as child.
as note: I have an ancient GT220 (3 displays)...
Maybe I can add some value like band pass filter that make adapting over time and it is displaced to the value/range more used habitually(according to amplitude, variations over time...) to multiply along after with a neuron output or weight.
I think store this value along the weight is more adecuate if this only happens in presinaptic and postsinaptic activity at same time, something only detectable by the relation and which this value update would create some kind of complete route starting from some input value until to some output in order to sensibilize for a past/specific input type.
It stays frozen only amplyfing for specific range of input values that was the more used making the function like some type of memory for a specific input or task without needs of disconnect weights for a new task and would do much more less effect over other neurons having trained weights for multiples task.
https://www.geogebra.org/m/kd5w84bt
the thickness would go narrowing on the time and making displacement every time more dificulty and it allow more refinement, force, contrast and differentiation for that route or input state allowing to put new neurons on the net for this or other tasks (with wide thickness and starting with low amplitude) because the differentiated neuron already only is accepting for specific weight values and transparent for others values because thickness already is short magnifing only where gradient descent led it.
Also I want test what happens if this differentiated weights are detected by the neuron and then could hold his output for more time according to the quantity of these
