Classic analog meter on the (dutch) DSMR meter
A vintage analog meter to display the power consumption in house, indicator when solar power is fed back to the mains power grid & mqtt
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Classic analog meter connected to the P1 port of the (dutch) DSMR Slimme Meter (domestic power meter) + mqtt logging of the data for use in OpenHab (or Domotics or....)
Hardware:
* esp8266
* vintage looking analog meter from AliExpress
* Green led to indicate power is fed back into the mains grid.
Software:
* Arduino sketch to read the "P1" port of the DSMR meter, PWM output to the analog meter + mqtt server connection for logging.
Scale of the meter was custom drawn to match the needed range.
