Visualizing Transit with Alternative Displays
Part art project part utility. It's a WiFi connected BART map that shows the current location of north or south bound trains.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
It's a two PCB stack with a mask between to protect from light leak. The map designs are put directly into the copper, PCB mask and traces on the pcb giving the project a unique look that is pretty affordable to build. It's WiFi connected so it can connect to my custom backend that shows the current location of each BART train.
