Out goes the money
A project log for Not-so-dull free form clock
A smart, connected, free form circuit clock and bedside lamp for sleep scheduling
brennan-pBrennan P 07/19/2021 at 19:570 Comments
After too much time thinking about the project and deliberating over each individual design choice it's time to bite the bullet and order some parts. The selection of these parts has come from what materials are available, calculations I performed in previous logs and the datasheets of the ESP32. I haven't quite finalised the circuits for the entire device yet, but I have given enough parts to compensate for this.
The final parts list is as follows:
Part Item Amount Source Price per packet Amount in packet Number of packets Total cost
Front and back panels Acrylic 650cm^2 Bauhause 2 700cm^2 1 2
Structure wire 1mm Enamelled copper wire 10m Amazon 12 11m 1 12
Circuit wire 0.5mm Enamelled copper wire 5m Amazon 12 200g 1 12
3.3V Voltage regulator MEZD71201A-F 1 Digikey 2.9 1 1 2.9
Power supply SWI25-5-E-P5 1 Digikey 12.61 1 1 12.61
Controller ESP32 Wroom 32E 1 Digikey 2.52 1 1 2.52
N channel MOSFET FQU13N06LTU-WS 16 Digikey 0.496 1 16 7.936
P channel MOSFET FQU8P10TU‎ 8 Digikey 0.558 1 8 4.464
NPN BJT KSC1815YTA‎ 8 Digikey 1.73 1 8 13.84
R0 20ohm resistor 80 Amazon 5.99 100 1 5.99
R1+R3+R6 1kohm resistor 25 Digikey 0.0376 1 25 0.94
R2+R5 10kohm resistor 24 Digikey 0.0376 1 24 0.9024
R4 5.5ohm resistor 8 Digikey 0.038 1 8 0.304
C1 0.1 uF 2 Digikey 0.19 1 2 0.38
C2 22 uF 2 Digikey 0.3 1 2 0.6
C3/C4 1 uF 4 Digikey 0.32 1 4 1.28
LEDs 0.5W 5730 SMD LEDs 80 Digikey 9.59 100 1 9.59
barrel jack 721A‎ 1 Digikey 3.13 1 1 3.13
Encoder EN11-HSM1AF15‎ 1 Digikey 2.48 1 1 2.48
Controller programmer ESP32-DEVKITS‎ 1 Digikey 8.41 1 1 8.41
Total 104.2764
Decisions yet to be discussed but present in the parts list are:
I already have the LED and 20-ohm resistors and with the purchase of some wire, it will give me more than enough soldering to do until the rest of the parts arrive from Digikey.
