9 PWM from ESP-32
The first 6 are centre aligned together
The second 3 are centre aligned together with a 180degree offset to smooth out the power fluctuations.
Ideally they should be 3 each at 120degrees apart but the there are only two MCPWM blocks (with 6PWM each) and I cannot work out how to sync between them.
