Understanding & Fixing RGB Noise
A project log for Rämixx500 - Amiga 500+ Mainboard
Open Hardware Remake of this Commodore Masterpiece
edoardo-auteriEdoardo AUTERI 07/28/2021 at 02:100 Comments
I have been working to maximize Ramixx500 V2’s analogue RGB video output and interestingly I have found few improvement points that are essential:
In the Amiga environment the jail bars are probably generated by peak noise induced by a floating _CCK (clock out for the genlock) and empathised by bad quality shielding/grounding at cable ends, regardless the resolution or de-/interlaced PAL/NTSC video modes.
Tested with:
(schematic from amigawiki)
