Rev 2 board manufactured and assembled
A project log for Li-Ion Charger Automation
Automate cell information readout from a Liitokala Lii-500 charger by tapping into it's LCD interface
enkiEnki 08/05/2021 at 20:350 Comments
The REV 2 board has been manufactured and has been lying on my desk for a while now. Today I finally had time to solder connections, flash firmware and assemble everything:
Unfortunately I found out that I have made two rather big mistakes with the board:
  1. The FPC connector for the USB cable should be 1mm pitch not 0.5 mm.
  2. I put the LCD and MCU connectors "backwards" :).
The board was plugged into the LCD on the back and connected with a serial port instead of USB, the firmware now allows you to choose :).
