First Board Assembled
A project log for USB Connection Delay Stick V2
Cheap and Mass-Producible
david-scholtenDavid Scholten 09/18/2021 at 00:180 Comments
Well, here it is. The first board has been assembled which will now allow me to write and debug the micro controller code. Once this has been done I can send off the hex file for Digikey to pre-program onto the micros to avoid the programming problem.
But first to make a jig to align pins to actually connect to the micro-controller...
