Homebots
C++ Virtual Machine + Language compiler (in Typescript) + UI for programming esp8266
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Hello!
This is an open-source project to run instructions on esp8266 without the need of flashing new firmware for every change.
The main goal is to write some code in a browser (in an editor with a compiler) then send the instructions directly to any esp8266 connected to the internet, via WebSockets, with bidirectional communication.
More details on these repositories:
Compiler in Typescript, from Espresso to byte code
https://github.com/homebots/espresso-compiler
Virtual Machine in C++
https://github.com/homebots/vm
Docker image to compile the VM
https://github.com/homebots/homebots-sdk
UI and documentation for Espresso language
