#2 Final Design
A project log for Mini Hyperloop - Magnetic Levitation Train
Magnetically Levitating and driving small scale version of a Hyperloop
adrian-prinzAdrian Prinz 09/12/2023 at 10:230 Comments
Once the approximate dimensions and the concept were defined, the concept was adapted on the basis of the main limiting components (battery module, electronics - main PCB, track PCB).
From this followed the final design including the development of the electronics:
Tube and Track
Overall View
Front view
Top viewPod - moving vehicle
The Pod is devided in the capsule, which includes the battery and the moving platform, which includes the levitation system.
T
The levitation system is receives power from the battery via spring contacts. The capsule and moving platform are hold together with magnets, what allows for easy disassembly and charging of the capsule.
