Final Design Stage - Fiber Optic Collimation Tube Assembly
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 01/21/2017 at 13:522 Comments
Here it is, my final design for the fiber optic collimation tube (laser.) I have thoroughly tested it and it works very well and here are all the documentation and specifications;
Lens used in collimation assembly- achromatic doublet
David H Haffner Sr wrote 01/21/2017 at 17:52 point
Hey Ted, yes, it is circularly symmetrical, it is intended to allow the beam to travel in a one direction only, hence the 532nm bandpass filter (the one with the mirror side facing outward.) That's also the reason for the achromatic doublet lens, not only to reduce chromatic aberrations, but keep the beam parallel as well.
I really wanted a triplet lens but I am working with the supply of parts I already have on hand.
Ted Yapo wrote 01/21/2017 at 16:38 point
Hi David!  Is the lens circularly symmetric?  It looks like it modifies the beam in only one direction.
