CCD Circuit Complete/TCD1304AP/LTspice schematic design
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 02/26/2017 at 18:540 Comments
This is a final draft of the CCD driver circuit before I assemble it next month, it is powered by the DIP-40 Arduino compatible development board (using the ATmega1284P-PU MCU chip.) The ADC (AD7667,) will be seated on a Schmartboard (40pin) The first block will be the drive components for the TCD1304 itself because this unit needs to be separate as it will be fitted within the spectrometer enclosure,
The ADC and MCU, will be designed as an interface unit (on its own proto board,) that can be connected to the CCD via serial port connector mounted on the side of the spectrometer.
The LTspice schematics are below are posted in 2 blocks, top and bottom (it was the only way I could make it fit, that was legible.)
Below is the bill of materials;
