Atmega 2560 Triple Turret Stepper Motor Control Circuit Board
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 05/22/2017 at 07:522 Comments
This is REV B of my Mega 2560 stepper Motor control circuit driver control board, I had to fix the switches as they were not working properly, now they do since I debounced them, I am posting a YouTube video showing it's operation
Below is the Arduino breadboard schematic showing the entire layout;
Next is the Fritzing schematic;
Here is the schematic for the LM350T voltage regulator;
Next is an Arduino barebones breadboard layout;
A 4 panel snapshot view;
Muriel Green wrote 05/22/2017 at 15:33 point
Cool! Would you be willing to share the debounce function you wrote? I might need to debounce a breakbeam that I'm working on.
David H Haffner Sr wrote 05/22/2017 at 15:50 point
Hey Muriel, sure thing. 1st off though you really need the two 0.1uf caps and the 10k resistors at ground, because it eliminates any spikes from in-rush current at switch press (that's the hardware part,) now the software part;
//Variables will change
int ledState = HIGH;        //current state of the output pin
int buttonState;            //current reading from the input pin
int lastButtonState = LOW;  //the previous reading from the input pin
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
void loop() {
  //read the state of the switch into local variable
  int reading = digitalRead(button_1);/*Name U defined as "button"*/
  int reading = digitalRead(button_2);
  // check to see if U pressed the button
  //(i.e Input went from LOW to HIGH)
  // if switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    //whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        ledState = !ledState;
 Here is the entire code:
/*The circuit and code modified by me on 5/15/2017
  David H Haffner Sr as part of my prototype triple
  turret grating assembly, for my project 3D-Printable Raman Spectrometer
  http://hackaday.io/project/18126-3d-printable-raman-spectrometer
  The circuit as it stands now on a Mega 2560:
   LCD RS pin to digital pin 8
   LCD Enable pin to digital pin 9
   LCD D4 pin to digital pin 7
   LCD D5 pin to digital pin 6
   LCD D6 pin to digital pin 5
   LCD D7 pin to digital pin 4
   LCD R/W pin to ground
   LCD VSS pin to ground
   LCD VCC pin to 5V
   10K resistor:Trimmer POT
   ends to +5V and ground
   wiper to LCD VO pin (pin 3)
  Library originally added 18 Apr 2008
  by David A. Mellis
  library modified 5 Jul 2009
  by Limor Fried (http://www.ladyada.net)
  example added 9 Jul 2009
  by Tom Igoe
  modified 22 Nov 2010
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include
#include
#include
const int button_1 = 1;// variable for storing button's status(this is for my referene :))
const int button_2 = 0;// variable for storing button's status
const int ledPin = 13;
const int motorPin1 = 12;// IN1 on motor control board
const int motorPin2 = 11;// IN2
const int motorPin3 = 10;// IN3
const int motorPin4 =  9; // IN4
int val1 = 0;
int val2 = 0;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(21, 20, 19, 18, 17, 16);
const int stepsPerRevolution = 200;
//   Here set the stepper motor rotation step how much is a circle
int dim = stepsPerRevolution;
//  Set the step motor number and pin
Stepper myStepper(stepsPerRevolution, 13, 12, 11, 10);
void setup() {
  pinMode(3, INPUT_PULLUP);//Sets the buttons as input
  pinMode(ledPin, OUTPUT);
  pinMode(2, INPUT_PULLUP);
  //set initial LED state
  digitalWrite(ledPin, ledState);
  attachInterrupt(1, counterclockwise, FALLING);
  attachInterrupt(0, clockwise, FALLING);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Speed:");
  lcd.setCursor(10, 0);
  lcd.print("n/min");
  lcd.setCursor(0, 1);
  lcd.print("Direction:");
void loop() {
  int redaing = digitalRead(button_2);
  myStepper.step(dim);
  void Direction();
  //  Read the sensor values:
  int sensorReading = analogRead(A0);
  //  Map it to a range of 0-150:
  int motorSpeed = map(sensorReading, 0, 1023, 0, 150);
  //  Set the motor speed:
  if (motorSpeed > 0)
    Serial.begin(115200);
  val1 = digitalRead(1);
  if (val1 == HIGH)
    val2 = digitalRead(0);
  if (val2 == HIGH)
    myStepper.setSpeed(motorSpeed);
    lcd.setCursor(6, 0);
    lcd.print(float(float(motorSpeed) / float(200)));
void clockwise()
  //   clockwise rotation
  lcd.setCursor(10, 1);
  lcd.print(">>>>>>");
void counterclockwise()
  // anti-clockwise
  dim = -stepsPerRevolution;
  lcd.print("<<<<<<");
