Progress Update
A project log for GPSDO IEEE PTP Master
GPS disciplined DCXO with software temperature compensation and IEEE 1588 PTP master
robert-rouquetteRobert Rouquette 05/21/2022 at 18:260 Comments
I've decided to modify the design to use the TM4C1294 series MCU.  It has essentially the same feature as the MSP432, but with a higher clock speed and it is currently in-stock at multiple suppliers.
The CPU clock speed is nominally rated for 120MHz, but I have so far seen no issues overclocking it to 125 MHz to get a clean 8ns of timer resolution.  The 32-bit timers also seem to have no issue operating at 125 MHz.
I've added an e-ink display to the design for debug and status purposes, and also implemented DHCP and NTP.
I've been using an EK-TM4C1294XL eval board for prototyping. I'm currently working on an eval board layout for the DCXO and temperature sensor.  The GPS eval board should be arriving sometime next week.
