Tested Firmware Version
Battery controller probing requests. 0x0A=Atmel, 0x16=TI
Actual Current is signed.
Power management for the LC-Display.
Display will be scrolled (11 digits).
HRD can be connected to external devices like personal computers to transfer and store the extracted technical data.
https://github.com/peterloes/HRD/blob/master/Getting_Started_Tutorial/1_poster_overview.pdf
The standalone HRD features EFM32 ...the world´s most energy friendly microcontrollers
ARM Cortex-M3 EFM32G230F128
Code Snippets
Make quick changes to the Source Code.
https://github.com/peterloes/HRD/blob/master/Software/main.c
   /*! List of items which can be displayed
     * This array contains a list of items that can be displayed on the LCD.
     * Element 0 is a special case, it shows the name, version, and date of
     * the firmware image.  Usually up/down push buttons are used to select
     * the item to be displayed.
     * The order of these items may be rearranged by the user.  Single or
     * groups of entries can be de-activated by commenting them out.
static const ITEM l_Item[] =
{  // [1234567890123456]    Cmd                Frmt
    { ">>> HRDevice <<<",   SBS_NONE,            FRMT_FW_VERSION    },
    { "Battery at SMBus",   SBS_NONE,            FRMT_BAT_CTRL    },
    { "Supply Battery",     SBS_NONE,            FRMT_CR2032_BAT    },
    { "Manufacturer",       SBS_ManufacturerName,    FRMT_STRING    },
    { "Device Name",        SBS_DeviceName,        FRMT_STRING    },
    { "Device Type",        SBS_DeviceChemistry,    FRMT_STRING    },
    { "Serial Number",      SBS_SerialNumber,        FRMT_HEX    },
    { "Production Date",    SBS_ManufactureDate,    FRMT_DATE    },
https://github.com/peterloes/HRD/blob/master/Software/drivers/BatteryMon.c
    /*!@brief Probe List of supported Battery Controllers */
  static const BC_INFO l_ProbeList[] =
   {  //  addr    type        name (maximum 10 characters!)
   {  0x0A,    BCT_ATMEL,    "ATMEL"        },
   {  0x16,    BCT_TI,        "TI bq40z50",    },
   {  0x00,    BCT_UNKNOWN,    ""        }    // End of the list
https://github.com/peterloes/HRD/blob/master/Software/drivers/BatteryMon.h
/*!@brief SBS Commands
 * These are the defines for the registers of the battery controller.  Each
 * define contains the following bit fields:
 * - Bit 17:15 specify the controller type where the define belongs to.  Bit 16
 *   (0x10000) represents the Atmel controller, while bit 17 (0x20000) specifies
 *   the TI controller. If both bits are set (0x30000), the register exists in
 *   both controller types.  Bit 15 is used if no controller is connected to
 *   identify the remaining valid entries (where SBS_NONE is set).
 * - Bit 14:8 contains the number of bytes to read.  For 8, 16, or 32 bit values
 *   BatteryRegReadValue() is called, while for more than 4 bytes function
 *   BatteryRegReadBlock() will be used (block command).
 * - Bit 7:0 of the enum contains the address as used for the SBS commands sent
 *   via I2C.
 * All command sequences beginn with I²C device address to access the battery
 * controller.  The device address depends on the type of battery controller:
 * - 0x0A in case of Atmel, and
 * - 0x16 for the TI bq40z50.
 * The address can be probed via BatteryCtrlProbe().
 * @see
 * Functions BatteryRegReadValue() and BatteryRegReadBlock() use these enums.
 * A list of all registers can be found in document
 * <a href="../SBS_Commands.pdf">SBS Commands</a> and in the
 * <a href="../sluubc1b_Technical_Reference_bq40z50-R1.pdf">Technical Reference
 * Manual</a> of the Texas Instruments bq40z50 battery controller.
 * @note
 * Registers 0x60~0x78 and those marked by brackets, e.g. [0x50], cannot be
 * accessed when the battery device in "sealed" mode, which is the default
 * state.
typedef enum
    SBS_NONE = (-1),            //!< (-1) No Command / Address
    SBS_ManufacturerAccess = 0x30200,    //!< 0x00 ManufacturerAccess (legacy)
    SBS_RemainingCapacityAlarm,        //!< 0x01 Word: in [mAh / 10mWh]
    SBS_RemainingTimeAlarm,        //!< 0x02 Word: in [min]
    SBS_BatteryMode,            //!< 0x03 Word: in Hex
