Design challenge n.9: Arduino IDE Software functions
A project log for Green BMS
Open source Bluetooth Smart Battery Management System
sergio-ghirardelliSergio Ghirardelli 10/19/2021 at 10:070 Comments
Every software designer has their own way of programming, there is no single method.
My job is PLC (Programmable Logic Controller) programmer and therefore I developed my project on Arduino IDE using the methods and functions that I normally use in Ladder language.
First, I avoided using interrupts and the "delay" command: I made sure that the task always ran as smoothly as possible.
So where it was necessary to use timings, I did it via the "Millis ()" function, here is an example:
I have also created 2 typical PLC functions that are very important to me:
  1. TON = timer on
The function I created to use the TON is this:
    2. Positive and negative edges
The functions to use edges are this:
These functions, added to others that I have created, have allowed me to develop Attiny and Mega sketches as I like!!!
