You can use MakeTime as an indicator for your PC's performance. Or for anything else, for that matter. Here's an example of it being used as a CPU load monitor
or you can use more than one to make an instrument cluster
MakeTime is simply listening on the serial port for what it should be displaying and a python script sends the stats.
Arduino sketch
#include <Adafruit_NeoPixel.h>
#define LED_PIN 9
#define LED_COUNT 24
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
void setup()
strip.begin();
strip.show();
Serial.begin(115200);
Serial.setTimeout(100);
void loop()
String s;
int r, g, b, i;
uint32_t color;
s = Serial.readString();
if (s != "")
sscanf(s.c_str(), "%d %d %d", &r, &g, &b);
strip.clear();
for (i = 0; i < 19; i++)
color = 0x00101010;
if (r > i) color += 0x600000;
if (g > i) color += 0x006000;
if (b > i) color += 0x000060;
strip.setPixelColor((i + 15) % 24, color);
strip.show();
Python script for CPU load monitor
import serial
import psutil
serialPort = serial.Serial("COM6", 115200, xonxoff=False, rtscts=False, dsrdtr=False)
while (1):
cpu_percent = psutil.cpu_percent(interval=0.2)
str = "%d 0 0" % int(cpu_percent*19 / 100.0)
bstr = bytearray(str)
serialPort.write(bstr)
print cpu_percent, bstr
serialPort.close()
