The first step: the electronic part
This tutorial starts with the electronic part. After you finish this part, you can complete the tasks of the mechanical part. The following are the parts that need to be prepared before starting.
Step 2: Parts to be used
· One Arduino Nano development board
· One 12V power supply
· One stepping motor
· One stepping driver
· A breadboard
· One Bluetooth module
· One real-time clock
Step 3: Tools to be used
· Electric soldering iron
· Solder
· Small vise
· Sponge Copper
· Watchmaker glasses
When soldering, fix the circuit board with a small vise to prevent it from moving. When cleaning the soldering iron, use a steel wire ball instead of just going to the kitchen to find a sponge. Steel ball is better to use, and because of high temperature resistance, it has a longer life. Watchmaker's glasses can play a miraculous effect when welding, you can clearly see the situation of the solder joints. If the accessories are used properly, the assembly speed will obviously be much faster.
Step 4: Layout components
Before starting to weld the various parts, it is recommended that you arrange them one by one to see if they can fit together. Of course, if you are using a custom circuit board, this step can be skipped.
Due to the size, the stepper driver is placed on the side. However, the pads on the circuit board are not in contact with it, so it will not cause a short circuit problem. After starting welding, the stepper driver was changed to the opposite side. Since there are only three components, it is not difficult to find a location for them. In addition to layout issues, we have to prepare enough lines.
Step 5: Welding parts and cables
After arranging the positions of the various components, clamp the circuit board with a vise to start the soldering work. After getting the main components, we need to start wiring. Some lines on the parts are a bit longer, but they are not cut directly, but they are used in welding. Make a hole in the cable and make a solder bridge between it and the pins.
Here is the wiring:
Arduino D2 -> Bluetooth receiver
Arduino D3 -> Bluetooth transmitter
Arduino D10 -> stepper driver enable pin
Arduino D11 -> stepper driver stepping pin
Arduino D12 -> stepper driver orientation pin
Positive power supply -> Arduino Vin interface -> Stepper driver VMOT pin
Power negative -> Arduino ground wire -> Stepper driver ground pin -> Bluetooth ground wire
Arduino +5V -> stepper driver VDD (device operating voltage) -> Bluetooth VCC (circuit voltage)
Stepper driver 1B->Gray wire on stepper motor
Stepper driver 1A->Red wire on stepper motor
Stepper driver 2A->Yellow wire on stepper motor
Stepper driver 2B->green wire on stepper motor
Note: Not all stepper motors have the same pin color
Step 6: Final assembly
It may be a little messy during the final assembly, but it was successful in the end. If it fails, you can use the header instead of welding.
Step 7: Code used by Arduino
The code used this time is very simple. Since the working mode of the Bluetooth module is similar to the serial port, the SoftwareSerial library in Arduino is used to obtain the signal. In this way, there is no need to use the transmit and receive pins, and there is no need to disconnect the Bluetooth connection when modifying the program. In addition, Bluetooth can read the sent characters so that the stepper motor can be controlled to open and close the curtains. According to the circumference of the pulley, the rolling distance can also be controlled. Here is the code used, here you have to set the time.
Step 8: Android platform control App
To control the curtains on your mobile phone, you have to make an Android App. In this App, we need to set a switch button. In addition, in the App, we can also set the real-time clock and open and close the curtains regularly. I am more familiar with App Inventor as an App, but in order to practice my hands, I chose another tool-Android Studio. In addition, I also used the free application Bluetooth spp pro. In this app, sending "o" will open the curtains, and "c" will close the curtains.
Step 9: Assembly of mechanical parts
The following items are the parts we use in the mechanical part:
· 2 stepper motor pulleys
· 1 NEMA 17 motor bracket (it is better to find another spare)
· 1 5mm bolt
· 2 5mm nuts
· 1 angle bracket (best find another spare)
· Some screws
· Fishing line or other types of thin lines
Step 10: Tools to be used
· Scissors
· Super Glue
· Electric drill
Step 11: Install motors and pulleys on the windows
When installing the motor, just fix the motor bracket directly on the wall. Isn't it simple? The installation steps of the pulley are similar to the bracket, you can refer to the diagram above to complete the installation of the pulley. But in this way, a 6'-7' gap is created between the motor and the pulley. If there is no obsessive-compulsive disorder, just ignore it.
Step 12: Connect the fishing line
The most complicated step in making automatic curtains is coming. At the beginning, high-strength and low-extension wires were used, but later it was found that such low-extension wires were difficult to use. So I changed back to a normal fishing line, which has great extension. Wrap one end of the thread tightly around the pulley, and then use the other end to wrap around the pulley on the stepper motor. Then the two ends of the wire were tightened, and the prototype of such a small transmission mechanism appeared.
When hanging the curtain, clip some binding clips on the curtain. When the clip and the fishing line conflict, change the clip to the opposite direction, so that the whole mechanism will not get stuck in operation.
Step 13: Possible improvements in the future
You can hang automatic curtains on every window in your home, but then you have to name the Bluetooth module, or you have to confuse it. You can also use OSHPark to make your own customized circuit boards and attach connectors to the components.
