Betula simulation now catching up with the prototype.
A project log for Wolffia
An very very small relay computer and simulator.
peter-birchPeter Birch 10/04/2021 at 12:150 Comments
OK so the hardware lacks a schematic. So I have started coding a logic simulator in Golang for this project which runs in ordinary terminals (it's a T.U.I) This first simulation is also the first schematic.
You can see a recording of the simulator here:
The Betula simulation of the decode and state transition ROM
Here's a snapshot:
There are three address lines which are decode by the 7 relay encoder on the left. The eight select lines are connected to an array of diodes on the right which are going to make up the program read-only-memory of the Wolffia computer.
