• 1
    Solder in the servo headers
    NOTE: Trim the ground header really short on each end if you need to use the power rail headers that interfere. Then after soldering clip those short.
    Put the servo header rows into a breadboard upside down, then put the PCB over them (again upside down, the servo headers go on top of the PCB), and shake it a bit to level it all out. Solder one pin on one row, check it's flat, then solder the rest.
  • 2
    Solder on the signal header
    This goes on the bottom.
  • 3
    Solder in the breadboard power rail header(s) (optional)
    Install the board with the signal header down into the breadboard and look through the holes over the power rail to see which ones line up. Pull it up, insert 2x1 pin headers in those locations (or location) and then put the PCB back down and solder the other side.
