Working on the enclosure
A project log for OpenAirMonitor
A solar-powered, outdoor air quality monitor that transmits data over LoRaWAN and Bluetooth LE
gerrit-niezenGerrit Niezen 10/26/2021 at 13:020 Comments
The enclosure design is slowly coming to an end. Who knew that it would be so much work making a plastic box to put something in? The idea is that this enclosure will be mounted on the bottom of the solar panel, so that only the solar panel itself (on a mounting plate) needs to be connected to a lamp post.
