Streaming
A project log for Camera Shield for S2 Mini
OV2640 shield for the S2 Mini ESP32-S2 board.
dehipudeʃhipu 01/11/2023 at 22:100 Comments
It doesn't help much to have a camera on your robot, if you don't do anything with the video. Displaying it on a display is cool, but not really that useful when it has to be attached to the same device. Vision algorithms are still a bit too advanced to me, so I decided to try the other useful option: streaming it into a browser.
Displaying a single jpeg image taken with the camera was easy enough, but we want live video - can we do that? Turns out that we can, by using something called M-JPEG (for motion jpeg), and the multipart/x-mixed-replace MIME type. All we have to do is send the JPEG images separated with a boundary, each with its own http header. After a few hours of tinkering, I finally got something like this working:
import board
import busio
import esp32_camera
import asyncio
import socketpool
import wifi
from adafruit_httpserver.server import HTTPServer
from adafruit_httpserver.response import HTTPResponse
server = HTTPServer(socketpool.SocketPool(wifi.radio))
PORT = 80
BOUNDARY = "FRAME"
i2c = busio.I2C(scl=board.IO35, sda=board.IO33)
data_pins = (
    board.IO21, board.IO17, board.IO16, board.IO18,
    board.IO37, board.IO34, board.IO36, board.IO39,
cam = esp32_camera.Camera(
    data_pins=data_pins,
    pixel_clock_pin=board.IO12,
    vsync_pin=board.IO40,
    href_pin=board.IO38,
    pixel_format=esp32_camera.PixelFormat.JPEG,
    frame_size=esp32_camera.FrameSize.QVGA,
    i2c=i2c,
@server.route("/")
def base(request):
    with HTTPResponse(request) as response:
        response._send_headers(content_type='multipart/x-mixed-replace; boundary=%s' % BOUNDARY)
        while True:
            jpeg = cam.take()
            response._send_bytes(request.connection, b'--%s\r\n' % BOUNDARY)
    b'Content-Type: image/jpeg\r\nContent-Length: %d\r\n\r\n' % len(jpeg))
            response._send_bytes(request.connection, jpeg)
            response._send_bytes(request.connection, b'\r\n')
async def poll(interval):
    server.start(str(wifi.radio.ipv4_address), port=PORT)
    while True:
        server.poll()
        await asyncio.sleep(interval)
async def main():
    poll_task = asyncio.create_task(poll(0))
    await asyncio.gather(poll_task)
asyncio.run(main())
This works, but there is a small problem. As soon as we start streaming, the server stops responding to any other requests, and our robot would stop waking or doing anything else, because the loop that sends the video frames is not async.
I will need to modify how this particular http server works to make the endpoints into async functions, so that we can add an await command in the loop that sends the frames. But that is something for another day.
