Dual OpAmp breakout
A breadboard and schematic-friendly breakout for common dual op-amps. Socket your favorite dual (TL072, LM833, ...) and build your effect!
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
My goal is a newbie-friendly pcb that breaks out a dual op amp into a convenient layout for prototyping. Basically, it makes the breadboard match up better with a schematic so you can swap parts and dial in your favorite tone.
Many famous guitar effects use one or two dual op-amp chips, so this gives anyone a head start in their pedal-building exploration. Skip the kits, and build with what you have in your parts bin!
