Just a bad solder joint
A project log for Menorah555
Menorah with LED "candles" that are lit using a shamash (helper candle)
glennkubota-geekGlenn.Kubota (gee.k) 12/18/2021 at 04:080 Comments
Easy enough. There was just a bad solder joint on the LED current-limiting resistor. Was it my fault or can I blame it on gremlins?
