CFexpress Type B to SSD Adapter Converter
A cheap& quick DIY way to convert the NVMe SSD(2230) to CFexpress
Starting from
$26.90
Makerfabs has 1368 orders / 35reviews
Ships from China
The CFexpress card is normally used in high-standard digital SLR cameras, and the latest Xbox S series. Its Max reading rate can be up to 1000M...But the problem is that a CFexpress card is expensive, a 256G CFexpress card can be $250 at Amazon...
So i designed this converter, to make the SSD to CFexpress card. it features:
1. Fully compatible with NVMe SSD 2230, the SSD can be directly installed into the case, without any modification/processing of the SSD.
2. Consideration of the heatsink, by big arear of ENIG both top& bottom side, and also the top metal case.
3. HIGH-speed PCB layout, do not lead to any SSD speed losses.4.
4. Fully compatible with Cameras(with Standard CFexpress plot)/Xbox/card readers. The camera CFexpress slot can be closed the same as a standard CFexress card.
i manually made the metal case so may not good looking, but i ensure it works as intended. Planing to make a mold to produce it, depends on how many people may get interest on it
Simple Steps to install a 2230 NVMe SSD.
View all 3 project logs
  • 1
    SSD install
View all instructions
tywy wrote 06/13/2022 at 08:28 point
i hate sd card is possible using normal usb A flash disc to raspberry pi boot disc?
