maon
The most annoying order notifier
The maon (most annoying order notifier) makes sure you get notified for each new order placed in your shop.
Hardware
The maon is based on a toy police siren I found on the street and an esp8266 which was laying around in the office.
The siren originally had batteries as a power source, but those leaked and were not functional anymore. A simple switch was used to turn the light and motor on.
For this project I added an micro usb port for 5V power supply, an transistor to switch the motor and led on / off and an ESP8266 for the logical part.
Software
To develop the firmware the Arduino core for ESP8266 is used. Building and flashing is done with help of makeEspArduino. For more information on the software check out the git repository.
Yeah nice, but what it is doing?
Well rather simple... After boot the maon connects to the configured wifi. When the connection is established it fetches the order list from the shop via the webservice API described here. Then it will compare the highest order id that was fetched from the server, with the localy stored id. If the local id is the same it means no new order is present. But if the fetched id is higher then the local one, we got a new order! For this case the transistor will be switched "on" and thus the siren will receive power. The new id will also be saved locally.
After 10 seconds the siren will be stopped, the storage access will be finished and the wifi connection will be closed. Then the maon goes to sleep for 1 minute, just to start all over again afterwards.
What shop?
Currently only shops based on PrestaShop are supported.
maon.pdf
The shematic
Adobe Portable Document Format - 18.45 kB - 12/15/2021 at 10:48
Preview
Download
  • 1 × The siren aka the annoying part
  • 1 × ESP8266 ESP-07 Module
  • 1 × Micro USB board for power supply
  • 1 × PN222A tranistor for switching the sirene
  • 1
    Make some space
    To have more space available I removed the "separation plastic parts" of the battery holder.
    BeforeAfter
  • 2
    Solder
    Next I soldered the components on a small perfboard, based on the schematic.
    To connect power and the siren I exposed some single male pins, to which the wires will be soldered later.
  • 3
    Add micro usb connector
    IMO the opposite side of the switch, is the best place for the power input.
    I simply used some hot glue to attach the small board. I know not the best method, but as it perfectly fits it can not move forward or backward when (un-) plugging the cable, thus it holds (for now...)
    I also made a small cutout in the outer case to expose the connector.
View all 4 instructions
