The case 3d-model for the GGreg20_V3 module for personal use
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC 08/19/2022 at 07:090 Comments
IoT-devices, LLC has shared the case a 3D model for the GGreg20_V3 module for personal use by anyone.
You can order such a case as an option together with the GGreg20_V3 module, or you can download and print this model from two parts – top and bottom (you need to download both models).
GGreg20_V3 Case 3d-model source files collection:
https://sketchfab.com/iot-devices/collections/ggreg20_v3-case-d7fb99552f054ad5a7960c43e66bae18
The casing model assumes that JST-type side connectors will be installed on the GGreg20_V3 module board. You can view how the casing looks on the GGreg20_V3 module on the product page on the company’s website and on Tindie .
IoT-devices, LLC Team
News Source:
https://iot-devices.com.ua/en/ggreg20v3-case-3d-model-for-personal-use/
