This one once again had a progressive drying over several weeks. The trick is leaving it in until humidity levels off or the next rain cycle arrives. It needs direct sunlight to get the required heating.
Not so easy convey the difference on camera without a lighting angle that over emphasizes the difference, but there's a big difference between stock & dried. The difference is manely from the side.
