Hydroboard2 ready!
A project log for GrowNode - Plant Growing platform
GrowNode is a vertical framework to build IoT devices targeted to growing plants in a controlled environment.
ogghstogghst 01/17/2022 at 02:280 Comments
Second attempt to release a Water Tower system. this time I've added some MOSFETs to drive:
It has an onboard logic to keep the reservoir at desired temperature prior to water it (thus keeping the system on an acceptable temperature range through all the year)
The board is powered with 220V - 12V 10A power adaptor so it can manage quite a lot of power consumption.
see project website
