Finally a nice frame
A project log for CS 555
The 555 as circuit sculpture.
mabe42MaBe42 08/02/2022 at 17:020 Comments
I found a fitting frame at IKEA. With the original passe-partout and a grey background, the CS 555 is now ready for presentation. I drilled holes for the legs through the base and fixed them with hot glue. Now a can run it from outside using alligator clips.
Also with a schematic for a test circuit on the back side.
Now I consider this project finished.
