3D printable linear servo actuator
100 kg / 215 lb pushing/pulling force, 7mm/s piston speed, 100mm stroke (adjustable limitswitch)
Video link: https://www.youtube.com/watch?v=-c1JRt7FlQs
This a 3D printable linear Servo actuator. (version 2)
Old version: https://www.youtube.com/watch?v=NLscbeoIjAY
STL files: https://www.thingiverse.com/thing:5190314
Editable source files: https://www.cgtrader.com/3d-print-models/hobby-diy/robotics/3d-printable-linear-servo-actuator
All the bolts are M3x20, just the bolts are that i fixed the bearing blok to the spacer bolts are M3x10
Motor bolts M4
The bearings are 8mm(608zz)
Printed with PLA.
You can use any motor with that, the endstops and potantiometer will work accordingly.
I took the feedback from the 10-turn potentiometer with the arduino uno and converted it to position information. That is, we can get position data nicely, at the same time, we can program it as we want using bts7960(43a).
Making and more are available in the video.
  • 1
    Step 1
  • 2
    Step 2
View all instructions
