BW16 Stamp - Tiny 5GHz WiFi Dev Board
Super compact functional 5G Hz WiFi MCU in stamp size with power circuit, work out of the box
Public Chat
Want the best of 5G WiFi connectivity while still maintain super compact form factor? Then this is for you!
The super compact design allows for easy deployment on any kind of DIY platform as all pins are re-mapped to the breadboard-friendly 2.54 pitch castellated holes, and also power regulating circuit already added with a 1.25mm battery connector, once plug in the battery, its ready for deployment!
Don't know what this Ameba board (BW16) is capable of? Watch the short clip below,
To deploy a IoT microcontroller is often a pain as it requires portable power supply and efficient power regulation, and also to work well with most sensor and actuators, the pin pitch has to be breadboard friendly meaning 2.54mm apart from each other. To achieve this, I design this Ameba Stamp module, and it features,
1.  Add power circuit and battery connector to easily provide the power the IC needs
2. Re-map the previously 2mm pitch pins to breadboard-friendly 2.54 pitch pins design so as to better work with other electronic components
Both the schematic and PCB are open-source, and link is here,
https://oshwlab.com/xidameng/amebanano
pcbdoc - 112.79 kB - 01/19/2022 at 09:02
Download
x-zip-compressed - 8.91 kB - 01/19/2022 at 09:02
Download
  • 1 × Ameba RTL8720DN (BW16) module
  • #11 Interesting Chemistry with TFT_eSPI library
    SimonXi10/13/2022 at 02:30 1 comment
    Just having the display is far from our purpose, we need it to show colorful, dynamic and meaningful information. For that, we need a powerful and user-friendly graphic library, I have searched high and low and found out that the TFT_eSPI library might just be the right fit!
    TFT_eSPI is a very interesting and powerful Arduino library, you can use it for sensor data display in a meter form, you can also use it to display some important information (such as resistor color code), and you can even connect to the internet via the 5G WiFi on the BW16 to get the time and date and display on the screen as an internet clock, and even put your favorite movie poster in it and add animation to watch it again and again 😎
    Let's watch a video together to see all the above-mentioned features in action,
    I found this library works really well with BW16-Stamp, so I have created Pull Request on Github to add board configuration to the library, this way we can easily develop GUI feature for BW16-Stamp~
    The arduino sketch code used in the demo are from a maker VolosR, here are the link to his Github repository,
    https://github.com/VolosR/InternetClock180x60
    https://github.com/VolosR/ImageScroll
    https://github.com/VolosR/ResistorTTGO
  • #10 A good display need an input method
    SimonXi10/06/2022 at 07:39 0 comments
    ST7737 TFT SPI LCD display is a vivid and compact display that offer just enough visualization for many microcontrollers and their applications. However, a display without an input method feels void and not interesting, thus I plan to add an input method to the BW16 Stamp!
    There are many options out there,
    1. Push Buttons
    This is the most obvious and easiest ones to add, TTGO dev board has 2 user buttons on the sides of their microcontroller board and are perfect for many applications
    TTGO T-Display ESP32 WiFi And Bluetooth Module Development Board 1.14 Inch  LCD Control Board | Shopee SingaporeBut buttons are huge for BW16 Stamp and limited to only max 4 states (with 2 buttons) which might not be enough.
    2. 5-way Tactile Switch
    5-way tactile switch is just like a joy stick, but it can be slided up, down, right, left and pressed down, so essentially it's a 5-in-1 buttons
    5-way Tactile SwitchThis is good when you have many GPIO available, but for BW16 Stamp, our GPIO resources are also limited, so taking up 5 GPIO is a little to much.
    3.  Thumbwheel Switch
    This switch allows for rotation input, and press-down input which is very common on old-shool MP3/MP4 players
    Picture 1 of 12This is almost perfect, as it only need 3 GPIOs, but its size is still too big for our BW16 Stamp...
    4. 6-Axis Accelerometer + Gyro sensor
    A 6-axis sensor would enable battery-powered device for motion input, which are not limited to the combination of input pattern that other methods have, and they are generally quite small and packed with many interesting features such as "free fall detection", " single tap", "double tap", "rise-hand wakeup" and etc.  What's best? with a motion sensor like this, we can even run TinyML (Tensor Flow Lite for Microcontrollers) on BW16 Stamp!
    There are many 6-axis ICs, most popular one I guess is MPU-6050, which is good but a little expensive,
    So I got my eye on another model,
    LSM6DS3TR-C
    from STMicroelectronics, it's only 1/7 of the price to MPU-6050, and it offers many addition features while still can attain a surprising 3 uA in idle mode!
    So this really is a good fit for IoT device and BW16 Stamp!
    I will be working on adding this IC into the PCB design and hopefully be able to get some result soon!
    Stay tuned and happy making! ~~ :)
  • #9 The "perfect" version PCB finally arrives and works!
    SimonXi09/28/2022 at 11:03 0 comments
    Hooray! the latest "perfect" version has finally reached!
    I have tested with a few Arduino Graphic Libraries, but so far the one works the best is Adafruit ST7735 Library, as it supports a number of LCD drivers and sizes and come with a feature-rich API set.
    The biggest change to the previous version is the change of 160x80 footprint and correcting the wrong slide switch connection. However, this lesson have ot be learnt the hard way-- it took me weeks before I can get my hand on the latest PCB. So, despite all the goods in open-source community,
    Always double check your code/parts after using any 3rd party libraries!
    Anyway, I have ported the previous Wi-Fi Scanner project to this board, and let's watch a demo video together!
    Here is the code used in the example,
    #include <Adafruit_GFX.h>    // Core graphics library
    #include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
    #include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
    #include <SPI.h>
    #include <WiFi.h>
    #define TFT_CS         9
    #define TFT_RST        6 // Or set to -1 and connect to Arduino RESET pin
    #define TFT_DC         8
    Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
    void setup(void) {
      Serial.begin(115200);
      Serial.print(F("Hello! ST77xx TFT Test"));
      // use this initializer (uncomment) if using a 0.96" 160x80 TFT:
      tft.initR(INITR_MINI160x80);  // Init ST7735S mini display
      tft.setRotation(1); // retate 90 degrees
      tft.setCursor(3,2);
      Serial.println("test filling screen");
      testFillScreen();
      tft.fillScreen(ST77XX_BLACK);
      tft.invertDisplay(true);
      tft.setTextColor(ST77XX_BLUE);
      tft.setTextSize(1);
      tft.println("Ameba WiFi Scanner        ");
      // check for the presence of the shield:
      if (WiFi.status() == WL_NO_SHIELD) {
          Serial.println("WiFi shield not present");
          // don't continue:
          while (true);
      // Print WiFi MAC address:
      printMacAddress();
      // scan for existing networks:
      Serial.println("Scanning available networks...");
      listNetworks();
      Serial.println("done");
      delay(1000);
    void loop() {
      delay(100);
    void testFillScreen() {
        delay(200);
        tft.fillScreen(ST77XX_RED);
        delay(200);
        tft.fillScreen(ST77XX_GREEN);
        delay(200);
        tft.fillScreen(ST77XX_BLUE);
        delay(200);
        delay(200);
    void printMacAddress() {
        // the MAC address of your Wifi shield
        byte mac[6];
        tft.setCursor(tft.getCursorX()+3, tft.getCursorY());
        tft.setTextColor(ST77XX_GREEN);
        tft.setTextSize(1);
        tft.println("MAC Address:");
        // print your MAC address:
        WiFi.macAddress(mac);
        Serial.print("MAC: ");
        Serial.print(mac[0], HEX);
        tft.print(mac[0], HEX);
        tft.print(":");
        Serial.print(":");
        Serial.print(mac[1], HEX);
        tft.print(mac[1], HEX);
        tft.print(":");
        Serial.print(":");
        Serial.print(mac[2], HEX);
        tft.print(mac[2], HEX);
        tft.print(":");
        Serial.print(":");
        Serial.print(mac[3], HEX);
        tft.print(mac[3], HEX);
        tft.print(":");
        Serial.print(":");
        Serial.print(mac[4], HEX);
        tft.print(mac[4], HEX);
        tft.print(":");
        Serial.print(":");
        Serial.println(mac[5], HEX);
        tft.println(mac[5], HEX);
        tft.println();
    void listNetworks() {
        // scan for nearby networks:
        Serial.println("** Scan Networks **");
        int numSsid = WiFi.scanNetworks();
        if (numSsid == -1) {
            Serial.println("Couldn't get a wifi connection");
            while (true);
        // print the list of networks seen:
        Serial.print("number of available networks:");
        Serial.println(numSsid);
        tft.setCursor(3,2);
        tft.print("Number of WiFi found:");
        tft.println(numSsid);
        tft.println();
        // print the network number and name for each network found:
        for (int thisNet = 0; thisNet < numSsid; thisNet++) {
            Serial.print(thisNet);
            tft.print(thisNet);
            Serial.print(") ");
            tft.print(") ");
            Serial.print(WiFi.SSID(thisNet));
            tft.print(WiFi.SSID(thisNet));
            tft.print(" : ");
            Serial.print("\tSignal: ");
            Serial.print(WiFi.RSSI(thisNet));
            tft.print(WiFi.RSSI(thisNet));
     Serial....
  • #8 New Design On-the-way
    SimonXi09/08/2022 at 08:30 0 comments
    Due to a small flaw in the previous design, the LCD could not be soldered directly on the back of the BW16-Stamp, which was disappointing, this has taught me the important lesson once again -- don't take others' work as granted and perfect, always check and be careful, so that everybody's contribution to the open-source community won't go to waste.
    Anyway, this time around, I have re-design the board with correct footprint and symbol, measured all dimensions and angles to ensure it is correct this time.
    Schematic will be made public and available for download once I have received the PCB and confirm it is indeed working, but for now, we can have some previews,
    So stay tuned and wait for my good news!
  • #7 BW16-LCD Arrived
    SimonXi09/02/2022 at 10:09 0 comments
    After 2 weeks, the PCB finally has arrived at my place, and this is how it looks in its complete form,
    front and back (before soldering)
    Front view
    Back view
    As you can see, it looks quite nice with the screen attached. However, I got the screen FPC connector pitch wrong and now it only works without the display T _ T
    The width here is supposed to be 9mm wide, but it's 10.1mm now. This has taught me an important lesson -- when designing with 3rd party library/symbols, always check the dimension before use!!
    For now I can use isolated copper wire to make the connections, but it will be a mess as compare to soldering onto the PCB.
    Anyway, I will test with this version first, then fix the issues found and get a new version out, hopefully this time it will take less time~
  • #6 BW16 Stamp Upgrades | BW16-LCD
    SimonXi08/24/2022 at 06:07 0 comments
    In my previous project log, I have made BW16-Stamp to work with a baremetal & super tiny TFT color LCD display module( without a breakout board) with just a few wires and the result looks fantastic!
    The circuit is super simple, no additional components needed! and the price for such tiny display is around $0.7/unit, super affordable! The performance of the display is decent enough for such small form factor with 0.96" in size and 160x80p resolution, graphics are vivid and rich, the packaging of the module is also clean and intuitive.
    So I've decided to take this a bit further and implemented a major upgrade to the BW16-Stamp, which now becomes BW16-LCD!
    Schematics, PCB and 3D model
    Here is the schematics,
    And the PCB layout,
    The 3D rendered model
    Major changes
    1. Add a 0.6A rated slide switch to control the power
    I often found inserting and removing battery connector a big hassle, especially when the battery connector is next to other modules/connectors. So adding a slide switch solves the problem and cut down the power completely -- saving the quiescent current drawn from LDO when the whole module is in idle
    2. Add ST7735 TFT Color LCD module solder pad
    To eliminate the clutter of wires, we can put the soldering pad of the FPC cable from the display module on the back of the board, this way, we will have a more robust and neater connection between LCD and BW16-stamp
    3. Add M2 mounting holes
    For those who wish to make this into an accessory to carry around or mount onto another installation, 2 mounting holes can come handy
    That's all I can share now, the PCB is on its way to my place, once I received it, I will make some project using it and share it here in another log, so stay tuned!
  • #5 BW16 Stamp in action! | Ameba LCD
    SimonXi08/18/2022 at 02:36 0 comments
    Since BW16 Stamp is so small yet very powerful, why not give it a nice display so that it can show beautiful graphics while still performing tasks as intended?
    To add on a new element, we have to apply the same principle::
    minimal components, easy, cheap and power-saving
    Therefore, this time, we chose a baremetal SPI TFT LCD display module with NO breakout board!
    This is a SPI-interface 0.96" 1600x80 IPS Color TFT LCD Display that is driven by ST7735, it's super tiny and really cheap( ~$0.7)
    Surprisingly and contrary to common understanding, just buying the baremetal display is more than enough for a display project, as the display itself usually comes packed with necessary components and driver IC inside so users often only need to add minimal peripheral circuit in order to work with it. In this schematic, we can see that a common LCD display breakout board is of very simple design,
    With a well-design MCU and a stable power source, you may ignore all the peripheral circuit and still have a decent display performance.
    Here is how to connect to the BW16 Stamp,
    TP0   ----   NC
    TP1   ----   NC
    SDA   ----   PA12
    SCL   ----   PA14
    RS(DC)   ----   PA26
    RES   ----   PB3
    CS   ----   PA15
    GND   ----   GND
    NC   ----   NC
    VCC   ----   VCC
    LEDK(cathode)   ----   GND
    LEDA(anode)   ----   VCC
    GND   ----   GND
    Now, we just need to flash the example code to test its performance, to do that, we can use the "Adafruit ST7735" library downloadable from Arduino IDE. Here is the modified example code for BW16 stamp,
      This is a library for several Adafruit displays based on ST77* drivers.
      Works with the Adafruit 1.8" TFT Breakout w/SD card
        ----> http://www.adafruit.com/products/358
      The 1.8" TFT shield
        ----> https://www.adafruit.com/product/802
      The 1.44" TFT breakout
        ----> https://www.adafruit.com/product/2088
      The 1.14" TFT breakout
      ----> https://www.adafruit.com/product/4383
      The 1.3" TFT breakout
      ----> https://www.adafruit.com/product/4313
      The 1.54" TFT breakout
        ----> https://www.adafruit.com/product/3787
      The 1.69" TFT breakout
        ----> https://www.adafruit.com/product/5206
      The 2.0" TFT breakout
        ----> https://www.adafruit.com/product/4311
      as well as Adafruit raw 1.8" TFT display
        ----> http://www.adafruit.com/products/618
      Check out the links above for our tutorials and wiring diagrams.
      These displays use SPI to communicate, 4 or 5 pins are required to
      interface (RST is optional).
      Adafruit invests time and resources providing this open source code,
      please support Adafruit and open-source hardware by purchasing
      products from Adafruit!
      Written by Limor Fried/Ladyada for Adafruit Industries.
      MIT license, all text above must be included in any redistribution
    #include <SPI.h>
    #if defined(ARDUINO_FEATHER_ESP32) // Feather Huzzah32
      #define TFT_CS         14
      #define TFT_RST        15
      #define TFT_DC         32
    #elif defined(ESP8266)
      #define TFT_CS         4
      #define TFT_RST        16
      #define TFT_DC         5
    #else
      // For the breakout board, you can use any 2 or 3 pins.
      // These pins will also work for the 1.8" TFT shield.
      #define TFT_CS         9
      #define TFT_DC         8
    #endif
    // OPTION 1 (recommended) is to use the HARDWARE SPI pins, which are unique
    // to each board and not reassignable. For Arduino Uno: MOSI = pin 11 and
    // SCLK = pin 13....
  • #4 BW16-Stamp in Action! | Ameba Neo
    SimonXi06/23/2022 at 07:50 0 comments
    BW16-Stamp has been designed for a while, now it's time to see it in action, let's watch a demo video
    In this demo, you will notice there are a few interesting new features added,
    1. Auto Flash Enabled
    With the community contribution from jojoling, and some simple circuitry on the breadboard, you can now auto-flash the BW16-Stamp with a single click of button( with Arduino IDE).  This is very handy feature, as in the pursuit of a minimalist design, adding components like buttons and etc is gonna make the stamp much bigger and also more complex( you have to recall the button pressing sequence to get it into UART downlaod mode), thus adding this feature will make programming BW16-Stamp a no brainer.
    2. The side-mounted battery connector
    The side-mounted battery connector makes the entire profile much cleaner and thinner, which means higher possibilities to embed a project made from BW16-Stamp into small enclosure or 3D printed case
    3. The 2.54 Pitch Castellated Holes
    These holes work really well with breadboard, even for a temperory fixing with male pin headers. This also enable it to work with other breadboard-friendly compponents such as the Neopixel LED shown in the video, soldering the LED onto the stamp is truly a bliss.
  • #3 [BW16 Stamp] Version 2 is finally out
    SimonXi05/26/2022 at 09:50 0 comments
    I have designed a second version of the Ameba Stamp and have renamed it to "BW16 Stamp" which is more intuitive to most makers.
    In the previous log, I have mentioned that I would like to replace the LDO MAS1117 with DCDC convertor to save power from the relatively high quiescent current (2mA) that AMS1117 draws, but after searching for the parts and availablity, it appears that the global chip shortage still persists 😅
    Plus, replacing with DCDC convertor will also introduce many more passive components as compared to LDO, this will result in bigger PCB layout, higher price point and more complex PCB design.
    Therefore, I have done some research and located a new LDO -- RT9013, it works similar to AMS1117 LDO, but it requires much less passive components (only 2 de-coupling capacitors) and much much less quiescent current (≈25uA), which is about 80 times less than AMS1117 LDO.  The footprint of this IC is also much smaller than both the DCDC convertor and AMS1117, the price and availability is also a big bonus,
    The only downside however, is that it is only able to deliver 500mA power at max (AMS1117 delivers 1A), but in the 1 Ohm Resistor Energy Meter project, we have measure and observed that the max instantaneous current drawn from BW16 is around 200mA, so 500mA is good enough for many low power profile projects.
    The schematic is completed
    This is how it looks in 3D rendering,
    The second version will be open sourced later, so stay tuned for more updates~
  • #2 Improvements for 2nd edition
    SimonXi02/11/2022 at 03:25 0 comments
    1. Increase the board width to let the board fit into bread board more easily
    2. Increase the tolerance for the outer half holes so that the machining process will not damage too much of the holes' copper coating
    3. AMS1117 has too high of the static current drawn and only able to regulate the power when the batter is above 3.3 V, so I am going to replace with the DCDC power IC from RPI Pico as it can handle both high and low input voltage
View all 11 project logs
powiadam.ci wrote 10/06/2022 at 10:19 point
fuzix can run on this?
SimonXi wrote 10/06/2022 at 10:51 point
What is fuzix? You can use Arduino, MicroPython or the open source Realtek C SDK to program this board~
teraz wrote 10/07/2022 at 09:45 point
use google luke!
http://fuzix.org/
SimonXi wrote 10/13/2022 at 02:24 point
First time hearing "fuzix", sounds like an interesting project, but this board already supported C SDK, Arduino(C++), and MicroPython (Python), adding a new platform might not be the first priority :)
