AIRSPY SDR Dongle
A project log for Reverse engineering of an unknown 868MHz protocol
Reusing old 868 MHz equipment in openHAB
hebel23hebel23 01/21/2022 at 21:300 Comments
In the next step I try to receive a signal with an SDR Dongle and the software AIRSPY (SDR#).
OK, this looks good. I got a signal on 868.475MHz. the two peaks left and right beside the mid frequency is typical for a FSK (frequency shift keying) modulation.
